Introducción
To replace or install a SIM card in your Blackberry 7520, follow this guide.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
  1. Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Push back on the black slot, then grab hold on top of the black slot and pull back so the SIM card and black slot pull back. Push back on the black slot, then grab hold on top of the black slot and pull back so the SIM card and black slot pull back. Push back on the black slot, then grab hold on top of the black slot and pull back so the SIM card and black slot pull back.
    • Push back on the black slot, then grab hold on top of the black slot and pull back so the SIM card and black slot pull back.
  5. Remove the SIM card by sliding it out of the black tray. Insert  the replacement SIM card with the gold plated side with lines facing down. Fold the black tray down with the SIM card in and push forward until the tray "slides" into place.
    • Remove the SIM card by sliding it out of the black tray.
    • Insert the replacement SIM card with the gold plated side with lines facing down. Fold the black tray down with the SIM card in and push forward until the tray "slides" into place.
Conclusión
Nathan
Miembro Desde 18/01/10
31 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 5-7, Forte Winter 2010 Miembro de Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 3,965
