Saltar al contenido principal
Blackberry 7520 Motherboard Replacement
Qué necesitas
  1. Blackberry 7520 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Blackberry 7520 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 Motherboard Replacement: paso 2, imagen 1 de 3 Blackberry 7520 Motherboard Replacement: paso 2, imagen 2 de 3 Blackberry 7520 Motherboard Replacement: paso 2, imagen 3 de 3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 2 Blackberry 7520 Motherboard Replacement, Motherboard: paso 3, imagen 2 de 2
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Blackberry 7520 Motherboard Replacement: paso 4, imagen 1 de 2 Blackberry 7520 Motherboard Replacement: paso 4, imagen 2 de 2
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Blackberry 7520 Motherboard Replacement: paso 5, imagen 1 de 1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 Motherboard Replacement: paso 6, imagen 1 de 2 Blackberry 7520 Motherboard Replacement: paso 6, imagen 2 de 2
    • Slide the rear panel forward to reveal the motherboard.
  7. Blackberry 7520 Motherboard Replacement: paso 7, imagen 1 de 2 Blackberry 7520 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the indicated screws using a T6 Torx screwdriver.
  8. Blackberry 7520 Motherboard Replacement: paso 8, imagen 1 de 2 Blackberry 7520 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  9. Blackberry 7520 Motherboard Replacement: paso 9, imagen 1 de 2 Blackberry 7520 Motherboard Replacement: paso 9, imagen 2 de 2
    • Pull the metal plate away from the front panel of the cell phone.
  10. Blackberry 7520 Motherboard Replacement: paso 10, imagen 1 de 1
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
Conclusión
Nathan
Miembro Desde 01/18/10
31 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 5-7, Forte Winter 2010 Miembro de Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 3,608
