Saltar al contenido principal
Blackberry 7105t Keyboard Replacement
Qué necesitas
  1. Blackberry 7105t Keyboard Replacement, Blackberry 7105t Disassembly: paso 1, imagen 1 de 1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Keyboard Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Keyboard Replacement: paso 5, imagen 1 de 3 Blackberry 7105t Keyboard Replacement: paso 5, imagen 2 de 3 Blackberry 7105t Keyboard Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Keyboard Replacement: paso 6, imagen 1 de 1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Keyboard Replacement: paso 7, imagen 1 de 1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Keyboard Replacement, Second Disassembly: paso 8, imagen 1 de 1
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
  9. Blackberry 7105t Keyboard Replacement, Keyboard: paso 9, imagen 1 de 2 Blackberry 7105t Keyboard Replacement, Keyboard: paso 9, imagen 2 de 2
    • Use a plastic opening tool to lift up the two black clips indicated in the picture.
    • Hold on to the keyboard while unfastening the clips.
    • The keyboard will detach once the clips are unfastened.
Conclusión
CeeJay
Miembro Desde 10/28/09
19 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-17, Regan Fall 2009 Miembro de Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,825
