Saltar al contenido principal
Blackberry 7105t Disassembly
Qué necesitas
  1. Blackberry 7105t Disassembly, Blackberry 7105t Disassembly: paso 1, imagen 1 de 1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Disassembly: paso 2, imagen 1 de 1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Disassembly: paso 3, imagen 1 de 1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Disassembly: paso 4, imagen 1 de 1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Disassembly: paso 5, imagen 1 de 3 Blackberry 7105t Disassembly: paso 5, imagen 2 de 3 Blackberry 7105t Disassembly: paso 5, imagen 3 de 3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Disassembly: paso 6, imagen 1 de 1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Disassembly: paso 7, imagen 1 de 1
    • The black battery casing and logic board can now be separated for the following steps.
Conclusión
kelogan
Miembro Desde 11/04/09
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-17, Regan Fall 2009 Miembro de Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 2,164
