Saltar al contenido principal
BlackBerry Z10 Battery Replacement
  1. BlackBerry Z10 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the phone over so that the back cover faces up.
    • Locate the groove at the bottom center of the phone.
    • Press the groove with your thumb to release the edge of the case from the phone.
  2. BlackBerry Z10 Battery Replacement: paso 2, imagen 1 de 2 BlackBerry Z10 Battery Replacement: paso 2, imagen 2 de 2
    • Use your thumb and index finger to carefully open the sides of the phone.
    • Start from the bottom and work your fingers up along the sides of the phone until the back cover is completely separated from the body of the phone.
  3. BlackBerry Z10 Battery Replacement: paso 3, imagen 1 de 3 BlackBerry Z10 Battery Replacement: paso 3, imagen 2 de 3 BlackBerry Z10 Battery Replacement: paso 3, imagen 3 de 3
    • Lift the bottom corner of the battery with your fingers.
    • Remove the battery from the body of the phone.
Conclusión
6 personas más completaron esta guía.
Emie Lou Cruz
Miembro Desde 09/08/14
1,084 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 1-2, Bruce Fall 2014 Miembro de CSU Fullerton, Team 1-2, Bruce Fall 2014
CSUF-BRUCE-F14S1G2
3 Miembros
4 Guías creadas
Un comentario
Battery 🔋 full but in one minute to lower
And power off
Zezo1901 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 19
Ultimos 30 días: 29
Todo El Tiempo: 4,556
