Saltar al contenido principal
BlackBerry Torch 9860 Handset Disassembly
Qué necesitas
  1. BlackBerry Torch 9860 Handset Disassembly, BlackBerry Torch 9860: paso 1, imagen 1 de 2 BlackBerry Torch 9860 Handset Disassembly, BlackBerry Torch 9860: paso 1, imagen 2 de 2
    • Depress the battery cover release button and remove the battery cover
    • Remove the battery from the phone before continuing.
    • Slide the yellow button toward the battery to eject the SIM card
    • Remove the MicroSD card from the SD slot (if present)
  2. BlackBerry Torch 9860 Handset Disassembly: paso 2, imagen 1 de 2 BlackBerry Torch 9860 Handset Disassembly: paso 2, imagen 2 de 2
    • There will be a silver bezel around the edge (the dog ate mine!)
    • Insert pry tool near the padlock icon and gently work your way around the bezel to pry it off and reveal the screws.
  3. BlackBerry Torch 9860 Handset Disassembly: paso 3, imagen 1 de 2 BlackBerry Torch 9860 Handset Disassembly: paso 3, imagen 2 de 2
    • Grab your T5 Torx screwdriver, and remove all 8 screws
    • Be careful when taking out screws. The silver ones go in the corners, black ones in the middle
  4. BlackBerry Torch 9860 Handset Disassembly: paso 4, imagen 1 de 2 BlackBerry Torch 9860 Handset Disassembly: paso 4, imagen 2 de 2
    • With the 8 screws removed, you can gently pry the back cover off. Be gentle, as it is still connected by a ribbon cable
    • Gently pry ribbon cable off, and then you will have the back cover fully removed
  5. BlackBerry Torch 9860 Handset Disassembly: paso 5, imagen 1 de 3 BlackBerry Torch 9860 Handset Disassembly: paso 5, imagen 2 de 3 BlackBerry Torch 9860 Handset Disassembly: paso 5, imagen 3 de 3
    • The next step is to remove the board.
    • There are 3 ribbon cables connected to it
    • Disconnect the first ribbon cable
    • When you remove the second ribbon cable it will reveal the third ribbon cable
  6. BlackBerry Torch 9860 Handset Disassembly: paso 6, imagen 1 de 3 BlackBerry Torch 9860 Handset Disassembly: paso 6, imagen 2 de 3 BlackBerry Torch 9860 Handset Disassembly: paso 6, imagen 3 de 3
    • With the 3 ribbon cables disconnected you can gently pry the board up and away from phone
    • With the board removed, you can then simply lift out the LCD display
  7. BlackBerry Torch 9860 Handset Disassembly: paso 7, imagen 1 de 1
    • Once the LCD is removed, the handset disassembled.
Conclusión
7 personas más completaron esta guía.
daniel
Miembro Desde 12/22/11
380 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 17
Todo El Tiempo: 7,071
