Saltar al contenido principal
BlackBerry R900M Case Disassembly
Qué necesitas
  1. BlackBerry R900M Case Disassembly, Case Disassembly: paso 1, imagen 1 de 1
    • Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
  2. BlackBerry R900M Case Disassembly: paso 2, imagen 1 de 1
    • Remove the backside of the device and set aside for later use.
  3. BlackBerry R900M Case Disassembly: paso 3, imagen 1 de 2 BlackBerry R900M Case Disassembly: paso 3, imagen 2 de 2
    • Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
  4. BlackBerry R900M Case Disassembly: paso 4, imagen 1 de 1
    • Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
  5. BlackBerry R900M Case Disassembly: paso 5, imagen 1 de 2 BlackBerry R900M Case Disassembly: paso 5, imagen 2 de 2
    • Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
    • Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • One is located below the scrollwheel.
    • Another is located behind the screen.
Conclusión
Equipo
Cal Poly, Team 33-83, Johann Spring 2010 Miembro de Cal Poly, Team 33-83, Johann Spring 2010
CPSU-JOHANN-S10S33G83
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,071
