Saltar al contenido principal
BlackBerry PlayBook Speaker Replacement
Qué necesitas
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: paso 1, imagen 1 de 2 BlackBerry PlayBook Speaker Replacement, Remove Back Panel: paso 1, imagen 2 de 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: paso 2, imagen 1 de 1
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: paso 3, imagen 1 de 2 BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: paso 3, imagen 2 de 2
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: paso 4, imagen 1 de 2 BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: paso 4, imagen 2 de 2
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: paso 5, imagen 1 de 1
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: paso 6, imagen 1 de 2 BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: paso 6, imagen 2 de 2
    • Lift the right speaker bar to remove it.
Conclusión
Una persona más ha completado esta guía.
Nathan
Miembro Desde 10/12/14
661 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 14-27, Maness Fall 2014 Miembro de Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 969
