Saltar al contenido principal
BlackBerry Pearl 8100 Disassembly
Qué necesitas
  1. BlackBerry Pearl 8100 Disassembly, Rear Cover: paso 1, imagen 1 de 1
    • Push the button indicated by the yellow marker to remove the rear cover.
    • Remove the battery (not pictured).
  2. BlackBerry Pearl 8100 Disassembly, Screws underneath the rear cover: paso 2, imagen 1 de 1
    • Use a T6 Torx screwdriver to remove the two screws indicated by the yellow markers.
  3. BlackBerry Pearl 8100 Disassembly, Bottom Cover: paso 3, imagen 1 de 2 BlackBerry Pearl 8100 Disassembly, Bottom Cover: paso 3, imagen 2 de 2
    • Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone.
  4. BlackBerry Pearl 8100 Disassembly, Side Cover: paso 4, imagen 1 de 2 BlackBerry Pearl 8100 Disassembly, Side Cover: paso 4, imagen 2 de 2
    • Use the plastic opening tool to remove the side covers.
    • The side covers are attached to the cell phone with small plastic snaps. These snaps can be bent or broken easily.
  5. BlackBerry Pearl 8100 Disassembly, More screws: paso 5, imagen 1 de 1
    • With the bottom and side covers removed, the two screws indicated by yellow markers will be visible.
    • Use the T6 Torx screwdriver to remove the screws.
  6. BlackBerry Pearl 8100 Disassembly, Frame: paso 6, imagen 1 de 2 BlackBerry Pearl 8100 Disassembly, Frame: paso 6, imagen 2 de 2
    • With the screws removed, the frame can be detached.
  7. BlackBerry Pearl 8100 Disassembly, Logic Board: paso 7, imagen 1 de 2 BlackBerry Pearl 8100 Disassembly, Logic Board: paso 7, imagen 2 de 2
    • Use the plastic opening tool to separate the motherboard from the front cover.
    • While removing the motherboard, the button that opens the rear cover may come loose along with a small spring. Do not lose these.
  8. BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: paso 8, imagen 1 de 2 BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: paso 8, imagen 2 de 2
    • Separate the keypad (first picture) and trackball (second picture) from the front cover.
    • Lift the piece of plastic that overlays the trackball (second picture). The trackball should then come loose.
    • Keep the trackball intact. The trackball has extremely small magnetic bolts underneath that are difficult to reassemble.
  9. BlackBerry Pearl 8100 Disassembly, Complete: paso 9, imagen 1 de 1
    • These are all the parts of the BlackBerry Pearl 8100 completely disassembled. From left to right, the parts are as follows: rear cover, front cover, motherboard, side covers, trackball, keypad, bottom cover, and frame.
Conclusión
Una persona más ha completado esta guía.
Justin
Miembro Desde 10/06/14
150 Reputación
2 Guías creadas
Equipo
Aristotle Miembro de Aristotle
Community
5 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 676
