Saltar al contenido principal
BlackBerry Curve 8900 Speaker Replacement
Qué necesitas
  1. BlackBerry Curve 8900 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Speaker Replacement: paso 2, imagen 1 de 2 BlackBerry Curve 8900 Speaker Replacement: paso 2, imagen 2 de 2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Speaker Replacement, Motherboard: paso 3, imagen 1 de 1
    • Remove the lower rear cover, using a small iFixit opening tool.
  4. BlackBerry Curve 8900 Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Speaker Replacement: paso 5, imagen 1 de 1
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Speaker Replacement: paso 6, imagen 1 de 2 BlackBerry Curve 8900 Speaker Replacement: paso 6, imagen 2 de 2
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Speaker Replacement: paso 7, imagen 1 de 2 BlackBerry Curve 8900 Speaker Replacement: paso 7, imagen 2 de 2
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Disconnect the antenna from the motherboard in the same manner.
  8. BlackBerry Curve 8900 Speaker Replacement: paso 8, imagen 1 de 1
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Speaker Replacement: paso 9, imagen 1 de 2 BlackBerry Curve 8900 Speaker Replacement: paso 9, imagen 2 de 2
    • Locate the chip underneath the screen.
    • Gently remove the screen, without applying too much pressure, taking care not to damage it.
  10. BlackBerry Curve 8900 Speaker Replacement: paso 10, imagen 1 de 2 BlackBerry Curve 8900 Speaker Replacement: paso 10, imagen 2 de 2
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
    • Remove the motherboard and place off to the side.
  11. BlackBerry Curve 8900 Speaker Replacement, Speaker: paso 11, imagen 1 de 1
    • Replace the entire center piece of the case to replace the speaker.
Conclusión
2 personas más completaron esta guía.
Johnny Tran
Miembro Desde 09/10/11
473 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-3, Zipperian Fall 2011 Miembro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 7,857
