Saltar al contenido principal
BlackBerry Curve 8900 Screen Replacement
Qué necesitas
  1. BlackBerry Curve 8900 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Open the rear panel to expose the battery and the chassis assembly. Remove the battery.
  2. BlackBerry Curve 8900 Screen Replacement: paso 2, imagen 1 de 1
    • Use a small, non-marring plastic opening tool to remove the lower-rear cover. (Credit cards and guitar picks work great.)
  3. BlackBerry Curve 8900 Screen Replacement: paso 3, imagen 1 de 1
    • Use a T6 Torx screwdriver to loosen and remove the six screws from the chassis as shown.
    • Flip the phone over to the front and remove the plastic bezel.
  4. BlackBerry Curve 8900 Screen Replacement: paso 4, imagen 1 de 1
    • Remove the midframe from the back of the phone, which should now be free after removing the screws. The green motherboard should now be exposed.
  5. BlackBerry Curve 8900 Screen Replacement: paso 5, imagen 1 de 1
    • Remove the front-cover by carefully prying the side release tabs, located on the side of the phone.
  6. BlackBerry Curve 8900 Screen Replacement: paso 6, imagen 1 de 3 BlackBerry Curve 8900 Screen Replacement: paso 6, imagen 2 de 3 BlackBerry Curve 8900 Screen Replacement: paso 6, imagen 3 de 3
    • Gently pry the side release tabs to lift the flexing keypad from the frame.
    • The navigation ball may come loose at this point. Set it aside with the keypad for reassembly.
  7. BlackBerry Curve 8900 Screen Replacement: paso 7, imagen 1 de 1
    • Gently lift the motherboard.
    • Locate the screen's ribbon cable underneath the motherboard, and detach it from the phone.
  8. BlackBerry Curve 8900 Screen Replacement: paso 8, imagen 1 de 2 BlackBerry Curve 8900 Screen Replacement: paso 8, imagen 2 de 2
    • Carefully pry at the sides of the screen until the display assembly is free. Remove the display from the motherboard unit.
Conclusión
4 personas más completaron esta guía.
Renae Bishop
Miembro Desde 09/07/11
68 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-3, Zipperian Fall 2011 Miembro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 4,316
