Saltar al contenido principal
BlackBerry Curve 8900 Microphone Replacement
Qué necesitas
  1. BlackBerry Curve 8900 Microphone Replacement, Microphone: paso 1, imagen 1 de 1
    • Press and slide the battery cover from the back of the device with your fingers.
    • Remove the battery by pulling it out.
    • The battery is shown outside of the device on the right side of the photograph, "BlackBerry D-X18."
  2. BlackBerry Curve 8900 Microphone Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    iFixit Opening Tool
    $1.99
    Comprar
    • Using the iFixit Opening Tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Microphone Replacement: paso 3, imagen 1 de 1
    T6 Torx Screwdriver
    $9.99
    Comprar
  4. BlackBerry Curve 8900 Microphone Replacement: paso 4, imagen 1 de 1
    iFixit Opening Tool
    $1.99
    Comprar
  5. BlackBerry Curve 8900 Microphone Replacement: paso 5, imagen 1 de 2 BlackBerry Curve 8900 Microphone Replacement: paso 5, imagen 2 de 2
    • Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
  6. BlackBerry Curve 8900 Microphone Replacement: paso 6, imagen 1 de 1
    • With your fingers, carefully remove the screen so as not to damage it.
  7. BlackBerry Curve 8900 Microphone Replacement: paso 7, imagen 1 de 2 BlackBerry Curve 8900 Microphone Replacement: paso 7, imagen 2 de 2
    • With your fingers, carefully unhook the antenna cable in all three locations.
  8. BlackBerry Curve 8900 Microphone Replacement: paso 8, imagen 1 de 1
    Spudger
    $3.99
    Comprar
    • Detach the ribbon cable on the front of the motherboard using the Spudger tool.
  9. BlackBerry Curve 8900 Microphone Replacement: paso 9, imagen 1 de 1
    • Detach the motherboard from both ribbon connections.
    • The ribbon connections are indicated by red circles on the photograph.
    • The ribbon connections are indicated by orange rectangles on the photograph.
  10. BlackBerry Curve 8900 Microphone Replacement: paso 10, imagen 1 de 2 BlackBerry Curve 8900 Microphone Replacement: paso 10, imagen 2 de 2
    • Replace the entire motherboard to replace the microphone.
Conclusión
Una persona más ha completado esta guía.
Johnny Tran
Miembro Desde 09/10/11
473 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-3, Zipperian Fall 2011 Miembro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 4,441
