Saltar al contenido principal
BlackBerry Curve 8900 Keypad Replacement
Qué necesitas
  1. BlackBerry Curve 8900 Keypad Replacement, Remove the battery: paso 1, imagen 1 de 1
    • Remove the back cover and the battery from the device.
  2. BlackBerry Curve 8900 Keypad Replacement, Remove the protective cover: paso 2, imagen 1 de 1
    • 4 screws should be visible. Pry off the lower portion of the back to reveal all 6 screws.
  3. BlackBerry Curve 8900 Keypad Replacement, Remove the screws from the midframe: paso 3, imagen 1 de 1
    • Remove all six T6 screws from the midframe.
  4. BlackBerry Curve 8900 Keypad Replacement, Split apart the device: paso 4, imagen 1 de 1
    • Separate the midframe from the rest of the device.
  5. BlackBerry Curve 8900 Keypad Replacement, Remove the motherboard: paso 5, imagen 1 de 1
    • Gently pry back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case prying the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  6. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: paso 6, imagen 1 de 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: paso 6, imagen 2 de 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: paso 6, imagen 3 de 3
    • Lift the keypad from the motherboard.
    • When replacing the keypad, be sure that the navigation ball is in its original position.
Conclusión
3 personas más completaron esta guía.
Renae Bishop
Miembro Desde 09/07/11
68 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-3, Zipperian Fall 2011 Miembro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 6,983
