Saltar al contenido principal
BlackBerry Curve 8900 Case Replacement
Qué necesitas
  1. BlackBerry Curve 8900 Case Replacement, Removing the Case: paso 1, imagen 1 de 2 BlackBerry Curve 8900 Case Replacement, Removing the Case: paso 1, imagen 2 de 2
    • Remove the rear cover from the phone.
    • Remove the battery.
  2. BlackBerry Curve 8900 Case Replacement, Remove the Rear Cover: paso 2, imagen 1 de 1
    • Using a small plastic opening tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Case Replacement, Unscrew the Midframe: paso 3, imagen 1 de 1
    • Remove the six screws from the midframe of the device.
    • Be careful not to damage the screws while removing them.
  4. BlackBerry Curve 8900 Case Replacement, Remove the Midframe: paso 4, imagen 1 de 1
    • Remove the midframe from the phone.
  5. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: paso 5, imagen 1 de 2 BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: paso 5, imagen 2 de 2
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case with the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
Conclusión
Use the new case and reassemble the phone by doing the instructions in reverse order.
2 personas más completaron esta guía.
Renae Bishop
Miembro Desde 09/07/11
68 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-3, Zipperian Fall 2011 Miembro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Miembros
8 Guías creadas
Un comentario
Excellent, please suggest me how can I get the replacement original case shipped to Gaborone, Botswana. I also need two screws shown at the top of the cell at step 3
d.arm1965 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 3,312
