Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Few tools are required to do this.
A small plastic pry tool or even a fingernail is sufficient. Working area surface should be clean and dry with adequate lighting.
Immediately wash hands after handling the battery and completing the process. Discard the dead battery properly.
  1. Remove the back cover of the phone. The battery will now be visible.
    • Remove the back cover of the phone. The battery will now be visible.
  2. On both sides of the battery, there are light grey half-circles. Using your fingers, pinch the battery along the grey half-circles and remove it from the device. On both sides of the battery, there are light grey half-circles. Using your fingers, pinch the battery along the grey half-circles and remove it from the device.
    • On both sides of the battery, there are light grey half-circles. Using your fingers, pinch the battery along the grey half-circles and remove it from the device.
Conclusión
Set aside the old battery, then replace it with the new battery. It should easily fit into place. Then, you can replace the backing of phone, pressing gently to secure it down.
Una persona más ha completado esta guía.
Renae Bishop
Miembro Desde 07/09/11
68 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-3, Zipperian Fall 2011 Miembro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 2,857
