Saltar al contenido principal
BlackBerry Curve 8530 Screen Replacement
Qué necesitas
  1. BlackBerry Curve 8530 Screen Replacement, Battery: paso 1, imagen 1 de 2 BlackBerry Curve 8530 Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
  2. BlackBerry Curve 8530 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pulling up from the top of the battery.
  3. BlackBerry Curve 8530 Screen Replacement, Keypad: paso 3, imagen 1 de 2 BlackBerry Curve 8530 Screen Replacement, Keypad: paso 3, imagen 2 de 2
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  4. BlackBerry Curve 8530 Screen Replacement: paso 4, imagen 1 de 2 BlackBerry Curve 8530 Screen Replacement: paso 4, imagen 2 de 2
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
  5. BlackBerry Curve 8530 Screen Replacement: paso 5, imagen 1 de 3 BlackBerry Curve 8530 Screen Replacement: paso 5, imagen 2 de 3 BlackBerry Curve 8530 Screen Replacement: paso 5, imagen 3 de 3
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  6. BlackBerry Curve 8530 Screen Replacement: paso 6, imagen 1 de 2 BlackBerry Curve 8530 Screen Replacement: paso 6, imagen 2 de 2
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
  7. BlackBerry Curve 8530 Screen Replacement, Screen: paso 7, imagen 1 de 3 BlackBerry Curve 8530 Screen Replacement, Screen: paso 7, imagen 2 de 3 BlackBerry Curve 8530 Screen Replacement, Screen: paso 7, imagen 3 de 3
    • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
    • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
    • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
  8. BlackBerry Curve 8530 Screen Replacement: paso 8, imagen 1 de 3 BlackBerry Curve 8530 Screen Replacement: paso 8, imagen 2 de 3 BlackBerry Curve 8530 Screen Replacement: paso 8, imagen 3 de 3
    • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
    • Use pressure to unlatch the screen from the clips.
    • Now that these clips have been undone, the screen should lift up easily.
Linea de Meta
7 personas más completaron esta guía.
Equipo
Cal Poly, Team 15-13, Regan Spring 2011 Miembro de Cal Poly, Team 15-13, Regan Spring 2011
CPSU-REGAN-S11S15G13
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 7,874
