Saltar al contenido principal
BlackBerry Curve 8520 Keyboard Cover Replacement
Qué necesitas
  1. BlackBerry Curve 8520 Keyboard Cover Replacement, Back Panel: paso 1, imagen 1 de 2 BlackBerry Curve 8520 Keyboard Cover Replacement, Back Panel: paso 1, imagen 2 de 2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Keyboard Cover Replacement, Battery: paso 2, imagen 1 de 2 BlackBerry Curve 8520 Keyboard Cover Replacement, Battery: paso 2, imagen 2 de 2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Keyboard Cover Replacement, Keyboard Cover: paso 3, imagen 1 de 2 BlackBerry Curve 8520 Keyboard Cover Replacement, Keyboard Cover: paso 3, imagen 2 de 2
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Keyboard Cover Replacement: paso 4, imagen 1 de 2 BlackBerry Curve 8520 Keyboard Cover Replacement: paso 4, imagen 2 de 2
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Keyboard Cover Replacement: paso 5, imagen 1 de 3 BlackBerry Curve 8520 Keyboard Cover Replacement: paso 5, imagen 2 de 3 BlackBerry Curve 8520 Keyboard Cover Replacement: paso 5, imagen 3 de 3
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Keyboard Cover Replacement: paso 6, imagen 1 de 3 BlackBerry Curve 8520 Keyboard Cover Replacement: paso 6, imagen 2 de 3 BlackBerry Curve 8520 Keyboard Cover Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
Conclusión
27 personas más completaron esta guía.
Matt
Miembro Desde 04/07/11
1,722 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-62, Walters Spring 2011 Miembro de Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 35,184
