Saltar al contenido principal
BlackBerry Curve 8310 LCD Screen Replacement
Qué necesitas
  1. BlackBerry Curve 8310 LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 LCD Screen Replacement, Lens: paso 3, imagen 1 de 1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 LCD Screen Replacement: paso 6, imagen 1 de 3 BlackBerry Curve 8310 LCD Screen Replacement: paso 6, imagen 2 de 3 BlackBerry Curve 8310 LCD Screen Replacement: paso 6, imagen 3 de 3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. BlackBerry Curve 8310 LCD Screen Replacement, Keyboard: paso 7, imagen 1 de 1
    • Remove the keyboard.
  8. BlackBerry Curve 8310 LCD Screen Replacement, Screen Housing: paso 8, imagen 1 de 1
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. BlackBerry Curve 8310 LCD Screen Replacement: paso 9, imagen 1 de 2 BlackBerry Curve 8310 LCD Screen Replacement: paso 9, imagen 2 de 2
    • Now remove the left and right side panels.
  10. BlackBerry Curve 8310 LCD Screen Replacement: paso 10, imagen 1 de 3 BlackBerry Curve 8310 LCD Screen Replacement: paso 10, imagen 2 de 3 BlackBerry Curve 8310 LCD Screen Replacement: paso 10, imagen 3 de 3
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
  11. BlackBerry Curve 8310 LCD Screen Replacement, LCD Screen: paso 11, imagen 1 de 1
    • Unplug the ribbon cable from the board.
    • The ribbon cable is located at the top left of the phone above the screen.
  12. BlackBerry Curve 8310 LCD Screen Replacement: paso 12, imagen 1 de 1
    • Insert tool between LCD screen and board.
    • Pry LCD screen from board.
Conclusión
4 personas más completaron esta guía.
Mandy Chan
Miembro Desde 01/20/12
91 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-32, Amido Winter 2012 Miembro de Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,779
