Saltar al contenido principal
BlackBerry Bold 9700 Keyboard Membrane Replacement
Qué necesitas
  1. BlackBerry Bold 9700 Keyboard Membrane Replacement, Motherboard Housing: paso 1, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement, Motherboard Housing: paso 1, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement, Motherboard Housing: paso 1, imagen 3 de 3
    • Remove the battery by prying the bottom of the battery upward.
    • Once the battery is angled up, pull it away from the top of the device.
    • Be sure to remove all power sources before working on electronic devices to avoid harming yourself or the device.
  2. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 2, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 2, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 2, imagen 3 de 3
    • Slide the SIM card from underneath the holding bracket upward toward the battery connector pins.
    • You must remove the SIM card before you can fully disassemble the device. Failure to do so may cause damage to components later on in this process.
  3. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 3, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 3, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 3, imagen 3 de 3
    • Pry off the AT&T logo panel with the plastic opening tool.
    • You will hear a snapping sound as the plastic tabs pop out.
  4. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 4, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 4, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 4, imagen 3 de 3
    • Use your T5 Torx screwdriver to remove the two black 5.57mm Torx head screws underneath the keyboard.
  5. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 5, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 5, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool to remove the frame of your device.
    • You will hear a snapping sound as the tabs pop out.
    • Once the case is loosened from the device, slide the case away from the top of the phone.
  6. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 6, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 6, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 6, imagen 3 de 3
    • Gently lift the bottom of the keyboard upward.
    • Pull the keyboard away from the bottom of the LCD display and lift upward.
  7. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 7, imagen 1 de 2 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 7, imagen 2 de 2
    • Remove the two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
  8. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 8, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 8, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 8, imagen 3 de 3
    • Gently pry up the ribbon connector at the top of the phone with a plastic opening tool.
    • Ribbon connectors are fragile. Too much force in the wrong place will damage the ribbon and may force you to replace an entire assembly.
  9. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 9, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 9, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 9, imagen 3 de 3
    • Remove the top two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
    • You should now have two 5.57mm black torx head screws and four 4.13mm steel Torx head screws off to the side. Do not lose them.
    • Lift the clear plastic cover directly upward.
  10. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 10, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 10, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 10, imagen 3 de 3
    • Grip the motherboard by the screen
    • Lift the board away from the base of the housing and vertically up.
  11. BlackBerry Bold 9700 Keyboard Membrane Replacement, Keyboard Membrane: paso 11, imagen 1 de 2 BlackBerry Bold 9700 Keyboard Membrane Replacement, Keyboard Membrane: paso 11, imagen 2 de 2
    • Use a conventional hair dryer to heat up the keyboard membrane.
    • On medium or low heat evenly heat up the membrane in the range of 5 to 10 minutes
    • Do not over heat the keyboard membrane. It should become soft to the touch when ready.
    • Removing the trackpad and LCD display prior to this repair is optional. Follow this guide to remove the trackpad, and this guide to remove the LCD display.
  12. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 12, imagen 1 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 12, imagen 2 de 3 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 12, imagen 3 de 3
    • Use a pair of tweezers to gently peal away the keyboard membrane.
    • Start from one of the top corners and regrip membrane in the center to completly remove the membrane.
  13. BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 13, imagen 1 de 2 BlackBerry Bold 9700 Keyboard Membrane Replacement: paso 13, imagen 2 de 2
    • Align the new keyboard membrane with gold conduits and press down onto circuit board.
Conclusión
Una persona más ha completado esta guía.
Danny
Miembro Desde 03/11/15
365 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,007
