Partes
No se requieren partes.
Remove the battery cover by applying pressure and sliding down to the silver square on the back of the phone.
  • Remove the battery cover by applying pressure and sliding down to the silver square on the back of the phone.
Agregar Comentario
Remove the battery by prying under it with your finger or the plastic opening tool. Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  • Remove the battery by prying under it with your finger or the plastic opening tool.
  • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
Agregar Comentario
Use a plastic opening tool (similar to the one shown) to carefully remove the two side bars of plastic. Use a plastic opening tool (similar to the one shown) to carefully remove the two side bars of plastic.
  • Use a plastic opening tool (similar to the one shown) to carefully remove the two side bars of plastic.
Agregar Comentario
Use the plastic opening tool to carefully pry the back casing off.
  • Use the plastic opening tool to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
Agregar Comentario
Pry off the front casing
  • Pry off the front casing
    • Be aware of sensors and other sensitive areas of the newly exposed electronics
Agregar Comentario
After removing the front from the outer casing, the track ball will come off attached to the casing.
  • After removing the front from the outer casing, the track ball will come off attached to the casing.
Agregar Comentario
Remove the track ball from the front case.
  • Remove the track ball from the front case.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
ryan
Miembro Desde 12/04/13
41 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-64, Johann Spring 2013 Miembro de Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 642
