Saltar al contenido principal
BlackBerry 7510 Logic Board Replacement
Qué necesitas
  1. BlackBerry 7510 Logic Board Replacement, Back Face of Phone: paso 1, imagen 1 de 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Logic Board Replacement: paso 2, imagen 1 de 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Logic Board Replacement: paso 3, imagen 1 de 1
    • Lift off the back cover.
  4. BlackBerry 7510 Logic Board Replacement: paso 4, imagen 1 de 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Logic Board Replacement: paso 5, imagen 1 de 2 BlackBerry 7510 Logic Board Replacement: paso 5, imagen 2 de 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Logic Board Replacement, Logic Board: paso 6, imagen 1 de 1
    • Using the T6 Torx screwdriver, remove the top screw.
  7. BlackBerry 7510 Logic Board Replacement: paso 7, imagen 1 de 1
    • Using your spudger, carefully pry off back plate.
    • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
  8. BlackBerry 7510 Logic Board Replacement: paso 8, imagen 1 de 1
    • Remove the front cover and keypad.
  9. BlackBerry 7510 Logic Board Replacement: paso 9, imagen 1 de 1
    • Remove one T6 Torx screw in the front bottom right of the board.
  10. BlackBerry 7510 Logic Board Replacement: paso 10, imagen 1 de 2 BlackBerry 7510 Logic Board Replacement: paso 10, imagen 2 de 2
    • Carefully pry the screen from the board with your spudger.
    • After prying it up, remove the screen from the board.
  11. BlackBerry 7510 Logic Board Replacement: paso 11, imagen 1 de 2 BlackBerry 7510 Logic Board Replacement: paso 11, imagen 2 de 2
    • Unscrew center T6 Torx screw in the center of the logic board.
    • Remove the logic board from the phone.
    • Replace with new logic board.
Conclusión
Neil Johnson
Miembro Desde 01/24/10
12 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-44, Regan Winter 2010 Miembro de Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,867
