Saltar al contenido principal
BlackBerry 7510 LCD Screen Replacement
Qué necesitas
  1. BlackBerry 7510 LCD Screen Replacement, Back Face of Phone: paso 1, imagen 1 de 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Lift off the back cover.
  4. BlackBerry 7510 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 LCD Screen Replacement: paso 5, imagen 1 de 2 BlackBerry 7510 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 LCD Screen Replacement, LCD Screen: paso 6, imagen 1 de 1
    • Unscrew the screw holding the back plate.
  7. BlackBerry 7510 LCD Screen Replacement: paso 7, imagen 1 de 2 BlackBerry 7510 LCD Screen Replacement: paso 7, imagen 2 de 2
    • Carefully pry off front cover. Make sure the plastic clips are unlatched before applying force.
    • Lift off front cover from metal plate.
  8. BlackBerry 7510 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Pry off the LCD screen with spudger at the two clips.
  9. BlackBerry 7510 LCD Screen Replacement: paso 9, imagen 1 de 2 BlackBerry 7510 LCD Screen Replacement: paso 9, imagen 2 de 2
    • Remove the LCD screen and replace it with a new one.
    • Careful not to rip the LCD ribbon.
Conclusión
Neil Johnson
Miembro Desde 01/24/10
12 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-44, Regan Winter 2010 Miembro de Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,588
