Saltar al contenido principal
BlackBerry 7510 Back Face of Phone Replacement
Qué necesitas
  1. BlackBerry 7510 Back Face of Phone Replacement, Back Face of Phone: paso 1, imagen 1 de 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Back Face of Phone Replacement: paso 2, imagen 1 de 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Back Face of Phone Replacement: paso 3, imagen 1 de 1
    • Lift off the back cover.
  4. BlackBerry 7510 Back Face of Phone Replacement: paso 4, imagen 1 de 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Back Face of Phone Replacement: paso 5, imagen 1 de 2 BlackBerry 7510 Back Face of Phone Replacement: paso 5, imagen 2 de 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
Conclusión
Equipo
Cal Poly, Team 14-44, Regan Winter 2010 Miembro de Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,543
