Saltar al contenido principal
BlackBerry 7280 LCD Screen and Speaker Replacement
Qué necesitas
  1. BlackBerry 7280 LCD Screen and Speaker Replacement, Battery: paso 1, imagen 1 de 3 BlackBerry 7280 LCD Screen and Speaker Replacement, Battery: paso 1, imagen 2 de 3 BlackBerry 7280 LCD Screen and Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 LCD Screen and Speaker Replacement: paso 2, imagen 1 de 2 BlackBerry 7280 LCD Screen and Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 LCD Screen and Speaker Replacement, SIM Card: paso 3, imagen 1 de 3 BlackBerry 7280 LCD Screen and Speaker Replacement, SIM Card: paso 3, imagen 2 de 3 BlackBerry 7280 LCD Screen and Speaker Replacement, SIM Card: paso 3, imagen 3 de 3
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 LCD Screen and Speaker Replacement, Back Case: paso 4, imagen 1 de 2 BlackBerry 7280 LCD Screen and Speaker Replacement, Back Case: paso 4, imagen 2 de 2
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 LCD Screen and Speaker Replacement: paso 5, imagen 1 de 2 BlackBerry 7280 LCD Screen and Speaker Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 LCD Screen and Speaker Replacement, Front Case: paso 6, imagen 1 de 2 BlackBerry 7280 LCD Screen and Speaker Replacement, Front Case: paso 6, imagen 2 de 2
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 LCD Screen and Speaker Replacement: paso 7, imagen 1 de 2 BlackBerry 7280 LCD Screen and Speaker Replacement: paso 7, imagen 2 de 2
    • Remove the front plastic case from the metal bracket.
  8. BlackBerry 7280 LCD Screen and Speaker Replacement, LCD Screen and Speaker: paso 8, imagen 1 de 2 BlackBerry 7280 LCD Screen and Speaker Replacement, LCD Screen and Speaker: paso 8, imagen 2 de 2
    • Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
Conclusión
Sarah Waddill
Miembro Desde 03/11/13
10 Reputación
5 Guías creadas
Equipo
Clemson, Team 12-2, Benson Spring 2013 Miembro de Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 366
