Introducción
The outer shell of the BlackBerry 7280 has two main parts, the back case and the front case. The back case is the first part that has to be removed, and allows access to more internal parts of the device.
Partes
No se requieren partes.
With your thumb press down on the locking- button on the back of the BlackBerry 7280.
  • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
  • Slide the battery cover off the device.
Agregar Comentario
Remove the lithium-ion battery from the back of the device using your index finger.
  • Remove the lithium-ion battery from the back of the device using your index finger.
Agregar Comentario
  • Hold the device with both hands.
  • Lift the SIM card holder using your thumb and index finger.
  • Remove the SIM card from the device.
Agregar Comentario
  • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
  • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
Agregar Comentario
  • Use the plastic opening tool to pry the back case away from the front case.
Agregar Comentario
Conclusión
Sarah Waddill
Miembro Desde 11/03/13
10 Reputación
5 Guías creadas
Equipo
Clemson, Team 12-2, Benson Spring 2013 Miembro de Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 242
