Saltar al contenido principal
BlackBerry 7130e battery replacement
Qué necesitas
  1. BlackBerry 7130e battery replacement, battery: paso 1, imagen 1 de 1
    • Turn the phone over so that the screen is facing the work surface
  2. BlackBerry 7130e battery replacement: paso 2, imagen 1 de 1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. BlackBerry 7130e battery replacement: paso 3, imagen 1 de 1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
Conclusión
Sean Tiernan
Miembro Desde 01/20/10
5 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-16, Maness Winter 2010 Miembro de Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 16
Todo El Tiempo: 2,986
