Introducción
How to replace the BlackBerry 7100g keypad cover.
Qué necesitas
Turn over your BalckBerry 7100g so that the back cover is facing up.
Locate the battery cover release button near the bottom of the back panel.
Locate the silver strip near the top of your BlackBerry.
Use a plastic opening tool to pry off the edge of the silver lining.
Slide the tool along the length of the silver strip to completely remove it.
Remove the keypad cover.
Insert the new keypad cover.
You are done replacing your keypad cover.
