Introducción
This guide shows you how to remove both the battery housing and the speaker.
Qué necesitas
Turn over your BalckBerry 7100g so that the back cover is facing up.
Locate the battery cover release button near the bottom of the back panel.
Locate the silver strip near the top of your BlackBerry.
Use a plastic opening tool to pry off the edge of the silver lining.
Slide the tool along the length of the silver strip to completely remove it.
Turn over the motherboard so that the speaker is facing up.
Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
2 personas más completaron esta guía.
