Saltar al contenido principal
Black and Decker WP900 Power Cord Replacement
Qué necesitas
  1. Black and Decker WP900 Power Cord Replacement, Power Cord: paso 1, imagen 1 de 1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Cord Replacement: paso 2, imagen 1 de 1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Cord Replacement: paso 3, imagen 1 de 3 Black and Decker WP900 Power Cord Replacement: paso 3, imagen 2 de 3 Black and Decker WP900 Power Cord Replacement: paso 3, imagen 3 de 3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Cord Replacement: paso 4, imagen 1 de 1
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Cord Replacement: paso 5, imagen 1 de 2 Black and Decker WP900 Power Cord Replacement: paso 5, imagen 2 de 2
    • Gently pull the power cord out from the control module.
    • This is the part to be replaced. Remember to insert the black wire into the top port when installing the new cord.
Conclusión
Cameron
Miembro Desde 02/15/16
231 Reputación
2 Guías creadas
Equipo
IUPUI, Team 8-8, Wilson Spring 2016 Miembro de IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 291
