Saltar al contenido principal
Black and Decker WP900 Motor Replacement
Qué necesitas
  1. Black and Decker WP900 Motor Replacement, Motor: paso 1, imagen 1 de 1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Motor Replacement: paso 2, imagen 1 de 1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Motor Replacement: paso 3, imagen 1 de 3 Black and Decker WP900 Motor Replacement: paso 3, imagen 2 de 3 Black and Decker WP900 Motor Replacement: paso 3, imagen 3 de 3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Motor Replacement: paso 4, imagen 1 de 1
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Motor Replacement: paso 5, imagen 1 de 2 Black and Decker WP900 Motor Replacement: paso 5, imagen 2 de 2
    • Gently pull the power cord out from the control module.
    • Remember, when you're reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Motor Replacement: paso 6, imagen 1 de 1
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel are attached to the motor.
  7. Black and Decker WP900 Motor Replacement: paso 7, imagen 1 de 2 Black and Decker WP900 Motor Replacement: paso 7, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 22mm screws securing the brush assembly to the motor.
  8. Black and Decker WP900 Motor Replacement: paso 8, imagen 1 de 2 Black and Decker WP900 Motor Replacement: paso 8, imagen 2 de 2
    • To fully remove the brush assembly from the motor, push the brushes (enclosed in the gold ribbing) outward and pull up.
  9. Black and Decker WP900 Motor Replacement: paso 9, imagen 1 de 1
    • With a large amount of force, pull the motor up and off of the wire coil.
Conclusión
Una persona más ha completado esta guía.
Stefan Wolowec
Miembro Desde 02/15/16
128 Reputación
1 Guía escrita
Equipo
IUPUI, Team 8-8, Wilson Spring 2016 Miembro de IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
4 Miembros
4 Guías creadas
Un comentario
Very straightforward tutotial. We are writing review of this product here https://www.helpful.reviews/en/product/4.... However we have not found many cases among owners of this product that they would need to repair motor by its replacement.
John Bazmek - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 27
Todo El Tiempo: 2,323
