Saltar al contenido principal
Black and Decker Toast R Oven Door Replacement
Qué necesitas
  1. Black and Decker Toast R Oven Door Replacement, How to clean out a Black and Decker Toast R Oven: paso 1, imagen 1 de 1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster over with its backside face down.
    • Remove the two Phillips #4 1cm screws that attach the side panels.
  2. Black and Decker Toast R Oven Door Replacement: paso 2, imagen 1 de 2 Black and Decker Toast R Oven Door Replacement: paso 2, imagen 2 de 2
    • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  3. Black and Decker Toast R Oven Door Replacement: paso 3, imagen 1 de 1
    • Remove the metal vent piece that is below the door.
    • This should slide off easily once both of the side panels are removed.
  4. Black and Decker Toast R Oven Door Replacement: paso 4, imagen 1 de 1
    • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Door Replacement: paso 5, imagen 1 de 1
    • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Door Replacement: paso 6, imagen 1 de 1
    • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  7. Black and Decker Toast R Oven Door Replacement: paso 7, imagen 1 de 1
    • Remove the knobs by pulling them upward; they should slide right off.
    • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
  8. Black and Decker Toast R Oven Door Replacement: paso 8, imagen 1 de 1
    • Unhook the bottom of the the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
  9. Black and Decker Toast R Oven Door Replacement: paso 9, imagen 1 de 1
    • Begin to detach the back panel from the toaster unit.
    • Then, unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
  10. Black and Decker Toast R Oven Door Replacement: paso 10, imagen 1 de 1
    • Finish removing the outside cover by lifting the lid upward.
  11. Black and Decker Toast R Oven Door Replacement: paso 11, imagen 1 de 1
    • Remove the four Phillips #4 1 cm screws from the back of the unit.
  12. Black and Decker Toast R Oven Door Replacement: paso 12, imagen 1 de 1
    • Now, you can clean the outside units of the toaster oven.
  13. Black and Decker Toast R Oven Door Replacement: paso 13, imagen 1 de 1
    • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
  14. Black and Decker Toast R Oven Door Replacement, Door Spring Mechanism: paso 14, imagen 1 de 2 Black and Decker Toast R Oven Door Replacement, Door Spring Mechanism: paso 14, imagen 2 de 2
    • Use the screwdriver to remove the spring from the unit.
    • Place the screwdriver inside the spring loop.
    • Pull to unhinge the spring from the back panel.
  15. Black and Decker Toast R Oven Door Replacement: paso 15, imagen 1 de 1
    • Remove the spring from the door mechanism by pulling it off.
    • Replace the old spring with a new spring.
    • When inserting a new spring, make sure that the spring is connected to the lower hole of the back panel (the hole above is used for the back casing).
  16. Black and Decker Toast R Oven Door Replacement, Door: paso 16, imagen 1 de 2 Black and Decker Toast R Oven Door Replacement, Door: paso 16, imagen 2 de 2
    • Use the pliers and a wrench to straighten the outdoor mechanism.
  17. Black and Decker Toast R Oven Door Replacement: paso 17, imagen 1 de 1
    • Take off the left side of the door by separating the unit from the hinge.
  18. Black and Decker Toast R Oven Door Replacement: paso 18, imagen 1 de 1
    • Separate the right side of the door from the unit as in the previous step.
  19. Black and Decker Toast R Oven Door Replacement: paso 19, imagen 1 de 1
    • Separate the door mechanism from the door by tilting the door to relieve the mechanism.
  20. Black and Decker Toast R Oven Door Replacement: paso 20, imagen 1 de 1
    • Unscrew the two door-handle screws.
Conclusión
4 personas más completaron esta guía.
Jonathan
Miembro Desde 09/18/12
281 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 2-10, Propen Fall 2012 Miembro de Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 Miembros
5 Guías creadas
2 comentarios
sale humo al momento de prender el horno
alo_68salud - Contestar
Thanks - you guide helped me ix my toaster oven.
Brian - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 41
Todo El Tiempo: 7,003
