Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
Black and Decker TR1278B Top Cover Replacement
Vistas: 8.5 k
Ver estadísticas:
Últimas 24 horas:
2
Últimos 7 días:
23
Últimos 30 días:
117
Todo El Tiempo:
8,481
Comentarios: 8
8 comentarios sobre los pasos.
Completado: 4
4 personas han marcado esta guía como "completada". ¿Serás tú la próxima persona en hacerlo?
Favoritos: 0
Nadie ha marcado como "Favorita" ni se ha suscrito a esta guía. ¿Quieres hacerlo tú?
Tiempo Requerido: Sin estimación
Dificultad: Moderado
Introducción
Ir al paso 1 ↓
To work on the inside of the toaster, the top cover must first be removed. This guide provides instructions on how to remove the top cover.
Qué necesitas
Herramientas
    1. Black and Decker TR1278B Top Cover Replacement, Top Cover: paso 1, imagen 1 de 1
      • Unplug the toaster before disassembly.
      • Remove the carriage lever by pulling it away from the toaster.
      Pregunta a FixBot
      Agregar Comentario
    2. Black and Decker TR1278B Top Cover Replacement: paso 2, imagen 1 de 1
      • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
      • Turn the toaster upside down.
      • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
      • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
      Pregunta a FixBot
      Agregar Comentario
    3. Black and Decker TR1278B Top Cover Replacement: paso 3, imagen 1 de 1
      • Detach the bottom from the front cover using the plastic opening tool.
      Pregunta a FixBot
      Agregar Comentario
    4. Black and Decker TR1278B Top Cover Replacement: paso 4, imagen 1 de 1
      • Turn the toaster right side up.
      • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
      • Lift the front cover.
      • Lift carefully. Again the ribbon cable can be damaged.
      Pregunta a FixBot
      Agregar Comentario
    5. Black and Decker TR1278B Top Cover Replacement: paso 5, imagen 1 de 1
      • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Autor
con
Dominic Gamonez
Miembro Desde 02/15/17
257 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-1, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
Miembros de 3
60 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 117
Todo El Tiempo: 8,481
