Saltar al contenido principal
Black and Decker TR1278B Top Cover Replacement
Qué necesitas
  1. Black and Decker TR1278B Top Cover Replacement, Top Cover: paso 1, imagen 1 de 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Top Cover Replacement: paso 2, imagen 1 de 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Top Cover Replacement: paso 3, imagen 1 de 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Top Cover Replacement: paso 4, imagen 1 de 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Top Cover Replacement: paso 5, imagen 1 de 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
Conclusión
2 personas más completaron esta guía.
Dominic Gamonez
Miembro Desde 02/15/17
233 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-1, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 96
Todo El Tiempo: 6,388
