Saltar al contenido principal
Black and Decker TR1278B Circuit Board Replacement
Qué necesitas
  1. Black and Decker TR1278B Circuit Board Replacement, Top Cover: paso 1, imagen 1 de 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Circuit Board Replacement: paso 2, imagen 1 de 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Circuit Board Replacement: paso 3, imagen 1 de 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Circuit Board Replacement: paso 4, imagen 1 de 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Circuit Board Replacement: paso 5, imagen 1 de 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Circuit Board Replacement, Circuit Board: paso 6, imagen 1 de 1
    • Locate the circuit board inside front cover.
  7. Black and Decker TR1278B Circuit Board Replacement: paso 7, imagen 1 de 2 Black and Decker TR1278B Circuit Board Replacement: paso 7, imagen 2 de 2
    • Use a Phillips head #2 screwdriver to unscrew all five screws that attach the circuit board to the top cover.
    • Remove the circuit board.
    • Inspect the circuit board for any burnt or otherwise damaged components.
    • Use a soldering kit to unsolder the damaged component.
    • Once the damaged component has been unsoldered from the circuit board, remove (and replace) it.
    • iFixit Soldering Guide.
Conclusión
Brea-Monique
Miembro Desde 02/15/17
384 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 8-1, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 29
Todo El Tiempo: 1,047
