Saltar al contenido principal
Black and Decker TO1303SB, TO1313B Top Cover Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Black and Decker TO1303SB, TO1313B Top Cover Replacement, Top Cover: paso 1, imagen 1 de 2 Black and Decker TO1303SB, TO1313B Top Cover Replacement, Top Cover: paso 1, imagen 2 de 2
    • Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
  2. Black and Decker TO1303SB, TO1313B Top Cover Replacement: paso 2, imagen 1 de 1
    • Remove the two 13mm screws, located between the feet on the bottom of the cover, using a Torx T15 screw driver.
    • On the TO1313SB, a Security Torx T15 driver is required — the screws have a center pin that prevents use of a regular T15 driver.
  3. Black and Decker TO1303SB, TO1313B Top Cover Replacement: paso 3, imagen 1 de 1
    • Using the metal spudger, carefully pry out the rubber base on each foot to access the screws.
  4. Black and Decker TO1303SB, TO1313B Top Cover Replacement: paso 4, imagen 1 de 1
    • Remove the 11.5 mm screws using a #2 Phillips screwdriver.
  5. Black and Decker TO1303SB, TO1313B Top Cover Replacement: paso 5, imagen 1 de 2 Black and Decker TO1303SB, TO1313B Top Cover Replacement: paso 5, imagen 2 de 2
    • Remove the back cover by gently pulling the sides of the cover apart from the rest of the oven. Then, tilt the cover towards the face and pull back at an upward angle. The cover should slide right off.
Conclusión
Barrett Lowe
Miembro Desde 10/08/15
207 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-11, Maness Fall 2015 Miembro de Cal Poly, Team 5-11, Maness Fall 2015
CPSU-MANESS-F15S5G11
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 73
