Saltar al contenido principal
Black and Decker SS12C Battery Replacement
Qué necesitas
  1. Black and Decker SS12C Battery Replacement, Battery: paso 1, imagen 1 de 3 Black and Decker SS12C Battery Replacement, Battery: paso 1, imagen 2 de 3 Black and Decker SS12C Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
  2. Black and Decker SS12C Battery Replacement: paso 2, imagen 1 de 1
    • Now that the battery component is detached, remove the 4 screws indicated [16mm].
    • Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
  3. Black and Decker SS12C Battery Replacement: paso 3, imagen 1 de 3 Black and Decker SS12C Battery Replacement: paso 3, imagen 2 de 3 Black and Decker SS12C Battery Replacement: paso 3, imagen 3 de 3
    • Now that the screws are detached, separate the two sides of the battery.
  4. Black and Decker SS12C Battery Replacement: paso 4, imagen 1 de 2 Black and Decker SS12C Battery Replacement: paso 4, imagen 2 de 2
    • Remove the highlighted, orange component and set aside.
  5. Black and Decker SS12C Battery Replacement: paso 5, imagen 1 de 3 Black and Decker SS12C Battery Replacement: paso 5, imagen 2 de 3 Black and Decker SS12C Battery Replacement: paso 5, imagen 3 de 3
    • Grip the battery pack and detach it from the casing by pulling it upward.
    • Spring may fall out during the process.
Conclusión
2 personas más completaron esta guía.
Un comentario
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
Scott D. Deutsch - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 864
