Saltar al contenido principal
Black and Decker Pivot MAX Battery Replacement
Qué necesitas
  1. Black and Decker Pivot MAX Battery Replacement, Battery: paso 1, imagen 1 de 2 Black and Decker Pivot MAX Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Battery Replacement: paso 3, imagen 1 de 1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Battery Replacement: paso 4, imagen 1 de 1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
Conclusión
25 personas más completaron esta guía.
Jesse Sipes
Miembro Desde 11/06/17
586 Reputación
2 Guías creadas
Equipo
IUPUI, Team S5-G6, Baechle Fall 2017 Miembro de IUPUI, Team S5-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G6
3 Miembros
5 Guías creadas
27 comentarios
any idea where to find the replacement battery? Does it come as a unit or do you need to disassemble the battery pack and replace the cells?
DMcDermott - Contestar
Where do I get the cells to replace the old ones?
Patricia Leat - Contestar
How do you disconnect the quick connect
DJ SmashBeatz - Contestar
My battery pack is soldered to a circuit board. There is no quick connect. (Model BDH2000PL, Type 2).
HBL - Contestar
Same here. Worst design ever.
James Watson -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 24
Ultimos 7 días: 140
Ultimos 30 días: 716
Todo El Tiempo: 44,833
