Introducción
This guide serves to aid users in replacing the battery of the Black and Decker PHV1810 Hand Vacuum. The battery inside a Black and Decker Hand Vacuum gives the device power and allows the vacuum to run. The Black and Decker Hand Vacuum battery will become worn out and degrade over time. This can cause shorter battery life, less output power of the battery, and even a non-working battery. This guide will show you how to replace this old and worn-out battery so you can use your vacuum for longer periods and generate more power to get the job done faster!
Before you begin make sure to be aware of the following:
- Check the owner manual for safety precautions that may be listed here
- Consider wearing gloves and/or eye protection as battery acid can be quite harmful to the skin
- Before you begin the disassembly of the product turn it on and leave it on until the motor completely stops ensuring the complete discharge of the battery
Does my Vacuum need a new battery?
- The Vacuum is not running as long as it used to on full charge
- The battery looks bloated
- Takes longer to charge
- Does not have the same amount of power and feels weaker
Finally, no special skills are required; it only requires eight simple steps to take apart and replace the battery.
Qué necesitas
To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
7 personas más completaron esta guía.
12 comentarios
“Remove the battery” sounds pretty simple, but my pivot vac seems to be “hard-connected” to the battery terminal, and I haven’t a clue where to go from here (though the trash heap—and recycling center—are strong candidates). Mine is an older model (2012) and perhaps that explains why these otherwise excellent instructions lead me to a dead-end.
Jim 4/14/21
the gray handle on one side pops open if you pry at it and there are screws underneath.
