Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Partes
No se especificaron partes.
  1. To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis. To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
    • To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
  2. Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device. Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
    • Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. Remove the three screws. Remove the three screws.
    • Remove the three screws.
  5. Flip the hand vac over and remove two screws. Flip the hand vac over and remove two screws.
    • Flip the hand vac over and remove two screws.
  6. Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off. Remove the L-shaped plastic hook. Once the L shaped hook has been removed the motor will easily fall out of place.
    • Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off.
    • Remove the L-shaped plastic hook.
    • Once the L shaped hook has been removed the motor will easily fall out of place.
    • Once the motor has been removed from its home the two wires that are giving it power can easily be removed by pulling on them carefully.
    • This will then allow for you to replace the motor.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 144
