Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If the nozzle, filter or catch bowl have been damaged in any way, or if you need to clean them, you can use this guide to remove or replace them in your Black and Decker PHV1810 Hand Vac.
  1. To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis. To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
    • To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
  2. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  3. Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device. Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
    • Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
Conclusión
What about the nozzle pre-filter?
Sean - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 116
