Introducción
Use this guide to remove or replace the circuit board in your Black and Decker LI2000.
Qué necesitas
Remove the following five screws
Three 20 mm Phillips #1 screws
One 10 mm #000 Phillips screw
One 13 mm Phillips 31 screw
Refer to the Soldering Technique Guide to remove the wires on the circuit board that connect the charging adapter by applying heat from iron to existing solder on the board.
Refer to the Soldering Technique Guide to remove the wires from the circuit board that connect to the battery by heating the existing solder on the leads.
