Saltar al contenido principal
Black and Decker LI2000 Charging Port Replacement
Qué necesitas
  1. Black and Decker LI2000 Charging Port Replacement, Orange Casing: paso 1, imagen 1 de 3 Black and Decker LI2000 Charging Port Replacement, Orange Casing: paso 1, imagen 2 de 3 Black and Decker LI2000 Charging Port Replacement, Orange Casing: paso 1, imagen 3 de 3
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Charging Port Replacement: paso 2, imagen 1 de 1
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Charging Port Replacement: paso 3, imagen 1 de 1
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Charging Port Replacement: paso 4, imagen 1 de 1
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
  5. Black and Decker LI2000 Charging Port Replacement, Handle: paso 5, imagen 1 de 2 Black and Decker LI2000 Charging Port Replacement, Handle: paso 5, imagen 2 de 2
    • Remove the four 15mm Phillips #1 screws.
  6. Black and Decker LI2000 Charging Port Replacement: paso 6, imagen 1 de 2 Black and Decker LI2000 Charging Port Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to pry the casing apart.
  7. Black and Decker LI2000 Charging Port Replacement, Charging Port: paso 7, imagen 1 de 1
    • Pull the charging port and circuit board away from the casing.
  8. Black and Decker LI2000 Charging Port Replacement: paso 8, imagen 1 de 1
    • Refer to the Soldering Technique Guide to remove the wires at the charging port by heating the existing solder on the contacts.
    • Be sure to keep track of which wire was attached to each lead.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 1-3, Baechle Spring 2016 Miembro de IUPUI, Team 1-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 544
