Saltar al contenido principal
Black and Decker LDX172C LED Power Indicator Replacement
Qué necesitas
  1. Black and Decker LDX172C LED Power Indicator Replacement, LED Power Indicator: paso 1, imagen 1 de 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C LED Power Indicator Replacement: paso 2, imagen 1 de 1
    • Rotate the drill to it's left side - the chuck should be facing rightward. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C LED Power Indicator Replacement: paso 3, imagen 1 de 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the LED power indicator located just above the battery pack.
  4. Black and Decker LDX172C LED Power Indicator Replacement: paso 4, imagen 1 de 2 Black and Decker LDX172C LED Power Indicator Replacement: paso 4, imagen 2 de 2
    • The LED is located on a small surface mount circuit board that easily slides out of its mounting location.
    • The LED is removed by freeing the solder joints on the bottom side of the circuit board.
    • Place the new LED through the same holes and re-solder it.
    • To reassemble repeat directions in reverse order.
Conclusión
Casey
Miembro Desde 02/13/16
260 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-3, Wilson Spring 2016 Miembro de IUPUI, Team 3-3, Wilson Spring 2016
IUPUI-WILSON-S16S3G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 206
