Saltar al contenido principal
Black and Decker LDX 120C Gear Replacement
Qué necesitas
  1. Black and Decker LDX 120C Gear  Replacement, Outer Case: paso 1, imagen 1 de 1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Gear  Replacement: paso 2, imagen 1 de 1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Gear  Replacement: paso 3, imagen 1 de 1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Gear  Replacement: paso 4, imagen 1 de 1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Gear  Replacement: paso 5, imagen 1 de 1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Gear  Replacement: paso 6, imagen 1 de 1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Gear  Replacement: paso 7, imagen 1 de 1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Gear  Replacement, Gear: paso 8, imagen 1 de 1
    • After following the prerequisite guide you will be able to access the interior components of the drill.
  9. Black and Decker LDX 120C Gear  Replacement: paso 9, imagen 1 de 1
    • Gently remove the top part (motor and chuck) from the rest of the drill.
  10. Black and Decker LDX 120C Gear  Replacement: paso 10, imagen 1 de 1
    • Make sure you do that with care so that the connection doesn't get damaged.
  11. Black and Decker LDX 120C Gear  Replacement: paso 11, imagen 1 de 1
    • To be able to get into the gears you will need to separate the motor from the rest.
    • And then you will be able to access the gears which is located between the motor and the chuck.
  12. Black and Decker LDX 120C Gear  Replacement: paso 12, imagen 1 de 1
    • Twist the gauge to change between the gear.
    • If you don't hear a clicking sound then check the gears.
  13. Black and Decker LDX 120C Gear  Replacement: paso 13, imagen 1 de 1
    • Twist the gear and see if the three gears rotate without jamming.
  14. Black and Decker LDX 120C Gear  Replacement: paso 14, imagen 1 de 1
    • Check if any gear is chipped or broken in any way.
    • If it is then you will need to change the broken gear.
  15. Black and Decker LDX 120C Gear  Replacement: paso 15, imagen 1 de 1
    • Using the spudger place it under the gear as illustrated.
  16. Black and Decker LDX 120C Gear  Replacement: paso 16, imagen 1 de 1
    • The gear will remove with just a little amount of force.
  17. Black and Decker LDX 120C Gear  Replacement: paso 17, imagen 1 de 1
    • The gear has been removed and now can be replaced by another gear.
Conclusión
jeffrey zakka
Miembro Desde 02/09/16
735 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 11-5, Cheng Spring 2016 Miembro de USF Tampa, Team 11-5, Cheng Spring 2016
USFT-CHENG-S16S11G5
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 39
Todo El Tiempo: 2,037
