Saltar al contenido principal
Black and Decker JS660 Trigger Replacement
Qué necesitas
  1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: paso 1, imagen 1 de 2 Black and Decker JS660 Trigger Replacement, Housing Disassembly: paso 1, imagen 2 de 2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Trigger Replacement: paso 2, imagen 1 de 1
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Trigger Replacement, Power Cord: paso 3, imagen 1 de 1
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Trigger Replacement: paso 4, imagen 1 de 1
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Trigger Replacement: paso 5, imagen 1 de 1
    • Gently remove the black and white cord from the trigger assembly.
  6. Black and Decker JS660 Trigger Replacement, Trigger: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to press down on these tabs on the trigger assembly.
    • While the tab is depressed, the cord can be pulled out of the housing by using a moderate amount of force.
    • Each cord needs to be done separately.
  7. Black and Decker JS660 Trigger Replacement: paso 7, imagen 1 de 1
    • Remove pink wires from trigger assembly.
Conclusión
matt murray
Miembro Desde 01/27/17
682 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 22-9, Maness Winter 2017 Miembro de Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 1,433
