Saltar al contenido principal
Black and Decker JS660 Angle Lock Replacement
Qué necesitas
  1. Black and Decker JS660 Angle Lock Replacement, Base: paso 1, imagen 1 de 2 Black and Decker JS660 Angle Lock Replacement, Base: paso 1, imagen 2 de 2
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Angle Lock Replacement: paso 2, imagen 1 de 1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Angle Lock Replacement: paso 3, imagen 1 de 2 Black and Decker JS660 Angle Lock Replacement: paso 3, imagen 2 de 2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Angle Lock Replacement, Angle Lock: paso 4, imagen 1 de 3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: paso 4, imagen 2 de 3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: paso 4, imagen 3 de 3
    • Remove the screw marked and the lever will slide out easily
    • The black screw must next be removed.
    • After removing the screw the lever will slide out of the jigsaw.
Conclusión
Andrew Khouri
Miembro Desde 02/08/16
468 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 6-2, Eyestone Spring 2016 Miembro de USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 197
