Introducción
This guide shows users how to replace the motor in the Black and Decker Dustbuster Handheld Vacuum (Model No. HNVC115J22 ). If your vacuum doesn’t run and you suspect the motor is the problem, you could replace it. Replacing the motor may restore suction power back to your device; make sure that another part is not at fault instead of the motor before replacing it. This device contains a lithium battery, so be careful not to short it or damage it. A new motor will need to be purchased for this guide.
Qué necesitas
Una persona más ha completado esta guía.
