Saltar al contenido principal
Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement
Qué necesitas
  1. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement, Suction Rubber Seal: paso 1, imagen 1 de 1
    • Press to blue unlock buttons at the base of the nozzle in word and pull forward .
  2. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: paso 2, imagen 1 de 1
    • Locate rubber suction seal.
  3. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: paso 3, imagen 1 de 1
    • Insert a metal spudger in between white plastic and rubber seal and gently drag spudger around see you lifting gently much like opening a can.
  4. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: paso 4, imagen 1 de 1
    • Align slits on the bottom of new suction seal then press into those slits.
    • The seal should not come above white plastic.
    • If the nozzle does not connect to vacuum barrel, readjust seal and try to attach nozzle until it snaps into place.
Conclusión
Roberto Perez
Miembro Desde 03/31/17
101 Reputación
1 Guía escrita
Equipo
Un comentario
Where can I buy a new suction seal.
Alison Junk - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 2,355
