Saltar al contenido principal
Black and Decker DustBuster 15.6V Nozzle Brush Replacement
Qué necesitas
  1. Black and Decker DustBuster 15.6V Nozzle Brush Replacement, Nozzle Brush: paso 1, imagen 1 de 1
    • Lift Nozzle Brush until it clicks into fully erect position.
  2. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: paso 2, imagen 1 de 1
    • Apply a gentle, equal pressure outward, to the inside of both brush legs.
  3. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: paso 3, imagen 1 de 1
    • Remove one of the leg prongs from the hole it is inserted into.
  4. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: paso 4, imagen 1 de 1
    • Rotate the free leg forwards or backwards from the hole.
    • This relieves the pressure from the inside of the legs allowing you to freely remove the last leg from its hole.
  5. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: paso 5, imagen 1 de 1
    • Check each leg hole for debris and clear whats needed.
    • Insert a leg of the new brush into the correct hole, so the brush will click into its erect position.
    • Slide the other leg into its respective hole.
Conclusión
Jacob
Miembro Desde 03/15/17
101 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 354
