Saltar al contenido principal
Black and Decker CD2500 Motor Replacement
Qué necesitas
  1. Black and Decker CD2500 Motor Replacement, Motor (148331-03): paso 1, imagen 1 de 1
    • Use a Phillips head screwdriver to unscrew 8 (3/4 in) Phillips screws from the housing set. Keep the screws all together.
    • Carefully remove the top housing
  2. Black and Decker CD2500 Motor Replacement: paso 2, imagen 1 de 1
    • SHOCK WARNING: Ensure wire ends do NOT touch each other! Disconnect the battery from the drill by pulling out the 3 terminals.
    • Make sure the wires previously connected to the battery are moved away from the battery terminals.
    • Make sure the drill trigger assembly stays in place or a new guide will be necessary.
  3. Black and Decker CD2500 Motor Replacement: paso 3, imagen 1 de 1
    • Grab the drill head with one hand and the gear with the other.
    • Pull away the second large gear from the motor gear and lift the drill head and gear up and out of the housing set.
  4. Black and Decker CD2500 Motor Replacement: paso 4, imagen 1 de 1
    • Keep the drill head and gear assembly as one unit.
    • Make sure the gear assembly stays as one piece and the gold bearings do not fall off.
  5. Black and Decker CD2500 Motor Replacement: paso 5, imagen 1 de 2 Black and Decker CD2500 Motor Replacement: paso 5, imagen 2 de 2
    • Pull out the motor and lay it next to the drill; keep in mind that the white and red wires will still be attached to the motor.
  6. Black and Decker CD2500 Motor Replacement: paso 6, imagen 1 de 1
    • The needle nose pliers will be used to detach the wires.
    • WARNING: Take extra care when using the pliers to detach the wires as both wires and motor terminals are delicate.
    • Use the pliers to “slide” the narrow sides of the motor terminals where the wires are attached. Pinching terminals will make it difficult to remove the wire from the terminal.
  7. Black and Decker CD2500 Motor Replacement: paso 7, imagen 1 de 2 Black and Decker CD2500 Motor Replacement: paso 7, imagen 2 de 2
    • Install new motor.
    • Attach wires to the new motor; make sure that the red wire is inserted back into the positive terminal on the new motor. The positive terminal is denoted by a (+) symbol.
    • The white wire will be inserted back into the negative terminal on the new motor. The negative terminal is denoted by the (-) symbol.
    • Make sure that the motor sits in the lower housing with the two terminals vertically in line, with the positive/red terminal on top.
    • The motor should fit snugly in the lower housing.
  8. Black and Decker CD2500 Motor Replacement: paso 8, imagen 1 de 2 Black and Decker CD2500 Motor Replacement: paso 8, imagen 2 de 2
    • Use the pliers to "slide" the wide sides of the motor terminals to firmly secure the wires back to the terminals.
  9. Black and Decker CD2500 Motor Replacement: paso 9, imagen 1 de 3 Black and Decker CD2500 Motor Replacement: paso 9, imagen 2 de 3 Black and Decker CD2500 Motor Replacement: paso 9, imagen 3 de 3
    • Replace the gear and drill head assembly.
    • Put the drill head back into where it originally was secured. Make sure it lines up with the molding of the plastic housing. Move the second large gear into where it locks into the motor gear.
    • Make sure that the gold bearings and other small parts lock into the designated slots in the molding of the housing.
  10. Black and Decker CD2500 Motor Replacement: paso 10, imagen 1 de 1
    • Reconnect the battery wires to the battery terminals by fitting the wire terminals over the battery terminals where they were originally fitted.
  11. Black and Decker CD2500 Motor Replacement: paso 11, imagen 1 de 1
    • Put the upper housing back on the drill. make sure that the upper housing lines up with the lower housing screw holes.
    • Put all eight screws back in the slots.
    • Tighten the screws back into place with the Phillips head screwdriver.
    • After the screws are back in place, make sure they are all snug.
  12. Black and Decker CD2500 Motor Replacement: paso 12, imagen 1 de 1
    • Turn on and test out the drill to make sure the new motor works.
    • Congratulations on successfully installing your new motor!
Conclusión
Refer to this parts diagram if needed during these steps: http://www.ereplacementparts.com/images/...
Ashley
Miembro Desde 09/24/13
182 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 3,516
